la trouvé çà aussi
FUNCTION OF THE 4 DIP SWITCHES OF THE 6021:
DIP SW. #1)
[OFF]/[ON] -[OLDNEW] /[ONLY-NEW] extended function decoder codes and [OLDNEW] /[ONLY-NEW] “reverse direction” information.
To keep compatibility with old-fashioned decoders (from Zy to 701.13 through LME) use #1 OFF (see later);
DIP SW. #2)
[OFF]/[ON] -[OLD]/[NEW] Motorola format; Direction arrows on the Control 80f (6036) turn on.
DIP SW. #3)
Only for new Motorola format. It increases the speed at which info is sent to the track. In other words it decreases the time intervals between series of 18 pulses. Incompatible with some chips before 701.13 (it doesn’t work, e.g., with some chips LME03, LME=Lenz Märklin Electronics)
DIP SW. #4)
Voltage stabilization at +/-12 Volt.
If #1 OFF and #2 ON you actually have a mixture between new Motorola format and old function decoder format. The additional functions f1,f2,f3,f4 are working both with old decoders (e.g. digital crane decoder) and new ones (e.g. additional functions of the c95).
Please take into account that the 6021 reads the DIP switches only during the “power on” cycle or after a “reset” (“stop” and “go” pressed at the same time for about half a second). Therefore, changing the position of the DIP switches during normal operation has no effect.
Et en Français, cela donne :
FONCTION DES 4 commutateurs DIP du 6021:
DIP SW. N ° 1)
[OFF] / [ON] - [OLD NEW] / codes de décodage de fonction [ONLY-NEW] longues et [OLD NEW] / [ONLY-NEW] information “sens inverse”.
Pour conserver la compatibilité avec les décodeurs à l’ancienne (à partir de Zy à 701.13 travers LME) utiliser # 1 OFF (voir plus loin);
DIP SW. # 2)
[OFF] / [ON] - [OLD] / [NEW] format Motorola, flèches de direction de la 80F Control (6036) s’allument.
DIP SW. # 3)
Seulement pour le nouveau format Motorola. Il augmente la vitesse à laquelle les informations sont envoyées à la piste. En d’autres termes, il diminue les intervalles de temps entre les séries de 18 impulsions. Incompatible avec certaines puces avant 701.13 (cela ne fonctionne pas, par exemple, avec certaines puces LME03, LME = Lenz Märklin Electronics)
DIP SW. N ° 4)
Stabilisation de la tension à + / -12 volts.
Si # 1 et # 2 OFF ON vous avez fait un mélange entre le nouveau format Motorola et ancien format de décodeur de fonction. Les fonctions f1 supplémentaire, f2, f3, f4 travaillent à la fois avec les anciens décodeurs (ex. grue décodeur numérique) et les nouveaux (par exemple les fonctions supplémentaires de la c95).
Veuillez prendre en compte que le 6021 lectures commutateurs DIP seulement au cours de la “tension” du cycle ou après un “reset” (“stop” et “go” pressé en même temps pendant environ une demi-seconde). Par conséquent, en changeant la position des interrupteurs DIP pendant le fonctionnement normal n’a pas d’effet.
Yano
